How to get the coordinates of each vertex of a polygon?
1782
05-06-2020 03:10 AM
SiyabongaKubeka
Hi All
I am using a webmap. On it I can drop a point or draw a polygon. I can get the coordinates of the point. Now suppose I am drawing a polygon, how can I get the coordinates of each vertex? Please see my code below:
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>GIS Map for CRM</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.14/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.14/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
//alert("Project ID is equals to 0");
require(["esri/views/MapView",
"esri/WebMap", "esri/config",
"esri/widgets/Sketch",
"esri/layers/GraphicsLayer"],
function (MapView, WebMap, esriConfig, Sketch, GraphicsLayer) {
esriConfig.portalUrl = "https://portal.environment.gov.za/portal";
var webmap = new WebMap({
portalItem: {
var graphicsLayer = new GraphicsLayer();
var view = new MapView({
map: webmap,
//zoom: 14,
container: "viewDiv"
//var symbol = {
// type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
// style: "circle",
// color: "blue",
// size: "8px", // pixels
// outline: { // autocasts as new SimpleLineSymbol()
// color: [255, 255, 0],
// width: 1 // points
webmap.layers.add(graphicsLayer);
var sketch = new Sketch({
layer: graphicsLayer,
view: view,
//symbol: symbol,
creationMode: "update",
//availableCreateTools: ["point"]
//container: "viewDiv"
view.ui.add(sketch, {
position: "top-right"
//Listen to sketch widget's create event.
sketch.on('create', function (event) {
// check if the create event's state has changed to complete indicating
// the graphic create operation is completed.
if (event.state === "complete") {
if (view.zoom >= 11) {
let gra = event.graphic.clone();
event.graphic.layer.removeAll();
gra.symbol.color = "red";
gra.layer.add(gra);
console.log(view.zoom);
console.log("X = ", gra.geometry.x);
console.log("Y = ", gra.geometry.y);
console.log("Lat = ", event.graphic.geometry.latitude);
console.log("Long = ", event.graphic.geometry.longitude);
//lati = event.graphic.geometry.latitude;
//longi = event.graphic.geometry.longitude;
zoomLevel = view.zoom;
debugger;
else {
alert("please zoom in");
event.graphic.layer.remove(event.graphic);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
You have to loop through the rings of the polygon.
for (var i = 0; i < gra.geometry.rings.length; i++){
  for (var p = 0; p < gra.geometry.rings[i].length; p++){
    var LatLon = String(gra.geometry.rings[i][p]);‍‍‍
    console.log(LatLon);
SiyabongaKubeka
Thank you very much Robert, it works.
SaiCharanKoppula
I don't get the correct format of longitude and latitude even after using the method provided above
GerardoSevilla
Polygon is using spatial  Web Mercator coordinate reference system 3857. You will have to transform these coordinates from Web Mercator system to World Geodesic system 4326. I used the following code:
    let [x, y] = gra.geometry.rings[i][p];
    let lngLat = webMercatorUtils.xyToLngLat(x,y); //get an array with lng,lat
    vertices.push(lngLat);
