Train deep learning model error
1347
7
05-01-2020 02:46 PM
HumbertoPerotto
We are learning how to use deep learning and we have been using the examples provided by ESRI with very good results. We started working with our imagery and we are getting the message below. We have followed all the steps and we made sure we installed python. We are not able to identify the problem. Help will be greatly appreciated! Thanks!
DanPatterson_Retired
You didn't post the full error.  Could you copy and paste it here
Also, you would be advised to post the issue directly on the github site
GitHub - Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
HumbertoPerotto
Hello Dan,
Many thanks for the reply. Here is the code:
  File "c:\......\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\Scripts\TrainDeepLearningModel.py", line 4, in <module>
    import arcgis.learn
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\__init__.py", line 3, in <module>
    from . import (features, geoanalytics, geocoding, geometry,
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\features\__init__.py", line 28, in <module>
    from . import enrich_data
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\features\enrich_data.py", line 10, in <module>
    import arcgis.network as network
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\network\__init__.py", line 9, in <module>
    from . import analysis
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\network\analysis.py", line 3, in <module>
    from ._vrp import solve_vehicle_routing_problem, edit_vehicle_routing_problem
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\network\_vrp.py", line 6, in <module>
    from arcgis.mapping import MapImageLayer
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\mapping\__init__.py", line 8, in <module>
    from ._types import WebMap, WebScene, MapImageLayer, MapImageLayerManager, VectorTileLayer, OfflineMapAreaManager
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\mapping\_types.py", line 19, in <module>
    from arcgis.widgets import MapView
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\widgets\__init__.py", line 2, in <module>
    from arcgis.widgets._mapview import MapView
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\arcgis\widgets\_mapview.py", line 15, in <module>
    from ipywidgets import widgets
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\ipywidgets\__init__.py", line 23, in <module>
    from IPython import get_ipython
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\__init__.py", line 55, in <module>
    from .terminal.embed import embed
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\terminal\embed.py", line 16, in <module>
    from IPython.terminal.interactiveshell import TerminalInteractiveShell
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\terminal\interactiveshell.py", line 33, in <module>
    from .debugger import TerminalPdb, Pdb
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\terminal\debugger.py", line 8, in <module>
    from .shortcuts import suspend_to_bg, cursor_in_leading_ws
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\terminal\shortcuts.py", line 234, in <module>
    from IPython.lib.clipboard import (ClipboardEmpty,
  File "C:\......\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\deeplearning\Lib\site-packages\IPython\lib\clipboard.py", line 7, in <module>
    import IPython.utils.py3compat as py3compat
AttributeError: module 'IPython' has no attribute 'utils'
 Failed to execute (TrainDeepLearningModel).
Thanks in advance for your help!
Humberto
Ian_JoshuaVillar
Greetings, Humberto.
Have you already found a solution to this error? I also had encountered this error when I run the Train Deep Learning Model tool. I hope you already fix this problem.
Regards,
Ian
Jorge_EzequielCastillo
Good morning Humberto:
You have found a solution.
HumbertoPerotto
No, not yet. We are working on identifying what we did different, and once we have some more information we will post more questions.
Thanks a lot for asking!
Humberto
Best regard Humberto:
This error appeared because I had the ArcGIS desktop and ArcGis Pro was installed on another unit. I removed both programs and only have ArcGIS Pro on the drive as indicated by the installation.
The samples are captured as the guide says, that is, the circle draws the entire element.
I create a new project, I do not work in which it fails. When run, it advances to epoch 8 and fails.
I have not tried again, I appreciate if you find any solution.
See you soon.
GiuseppeDiCaprio
I've the same problem  , could anyone give me a solution to this problem?
Thanks in advance,
Giuseppe
ERROR 032659 updateParameters Execution Error: Traceback (most recent call last):
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx#TrainDeepLearningModel_ia.UpdateParameters.py", line 1, in <module>
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx#TrainDeepLearningModel_ia.UpdateParameters.py", line 66, in updateParameters
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\models\_maskrcnn.py", line 183, in _supported_backbones
return [*_resnet_family]
NameError: name '_resnet_family' is not defined
