Stream Service Outbound Transport Error
472
05-03-2020 10:30 AM
najeebhall
New Contributor III
I have suddenly started to get this error in my geo event manager for my email outputs. I am not sure what is causing this, it was working fine up until two days ago and i didn't change anything. what does this mean and how can i fix it?
Stefan_Jung
Hi najeeb hall‌,
the error message directly below the transport error might be more important. This could be a problem with RabbitMQ.
Check out this Post:
Geoevent Server Error : Failed to create connection cxn-34200 c
On which Version are you running? Did you install ArcGIS Server Patches or GeoEvent Patches?
Best,
Stefan
najeebhall
New Contributor III
Thank you for your response Stefan, The issue was that a patch was installed and the geoevent needed to be restarted
