Training Deep Learning Model
848
05-01-2020 12:49 PM
JaredVigil
Hello, I am trying to use ArcPros 2.5 "Training Deep Learning Model" tool but I am running into some errors I am not sure how to handle.
I got my training data from the "Lable Objects For Deep Learning" Imagery Tool. These are my export options.
And that runs fine. When I try putting this training data into the "Training Deep Learning Model " I am getting this error.
I have done some google but can't find too much out there to help me. These are the other input options I am putting into the tool
if you need me to explain more of what I am doing or what versions of stuff I am using let me know and I will get back to you asap. I have been stuck here for a bit. Thanks.
Elbertde_Hon
Hi, did you get an answer in the meantime to your question?
I would check if you installed the required python packages for deep learning right:
Install deep learning frameworks for ArcGIS—Help | Documentation
Beside that I would check if your folder with image chips, labels etc. contains the right content.
DanPatterson
MVP Esteemed Contributor
BUG-000129130: The Train Deep Learning Model tool does not recogniz..
there are lots of issues with deep learning, most come down to the package versions being installed
... sort of retired...
DavidHolzhacker
Hi, I also have a problem with the Deep Learning Training Model. When I want to train my Model with the Chips, I got this error. Please can someone help me...
