Network analyst- slope restrictions
716
04-30-2020 01:55 AM
DavidČernický
Hello!
I have a road network with attribute 'speed' and a DEM raster and I need to calculate the service area. I want to use the DEM raster to specify the speed in hilly areas. The idea is that the car goes uphill slower than down the hill. Is it possible to set a lower speed when going uphill and not to change the speed when going downhill? The speed depends on the steepness of the slope and slope values are divided into 4 categories.
Is it possible to set it in Network analyst using ArcGIS Pro or is it only possible using Python?
Thank you,
David
JaySandhu
A network dataset models a road with both sides of travel. Based on the direction of digitization, cost of travel can be specified on the From-To and To-From directions. Normally when you set up a cost attribute, you specify the two fields on the feature class that provide these two costs. As long as you can set up the values for the uphill/downhill costs, they can be loaded into the network and the Service Area solver will be able to use them. When you solve the Service Area you can specify the travel direction as From the facility or To the facility. That will use the appropriate direction of the slope costs into account.
The setting up of the data and the network dataset can be done with the Pro 2.5 using the property pages of the network dataset.  The main problem in setting up these cost fields will be loading the two fields (From-To and To-From) correctly from your DEM. You may need to do some scripting for that aspect.
Jay Sandhu
