Problems with Arcgis 10.8 and Kml.
303
04-28-2020 08:21 PM
TOBIAS_LP
I had a raster on magna sirgas and then I try to convert it on Kml, but when it finished, the kml was in other place (in the sea), so I try convert that raster to TIFF and IMG with the same result, so I decided change my coordinate system and I try with a geographic system (MAGNA) but I get the same result...unfortunately, So then I try my laptop with ARCGIS 10.7.1 and First Try ¡Success¡ (oh and before I try wit Arc catalog and I Fail too)
Has anyone else had the same problem, was it just me? is it an arcgis problem? if anyone has any clue i will be very grateful.
Thank you
TOBIAS_LP
Ok I found the answer, I need activate my background processing to get the KML correctly positioned, otherwise, Arcgis does not process the geographic transformation..
Thanks to ESRI.
