Portal for ArcGIS Search Widget Issue
681
04-21-2020 02:10 PM
AdamBakiera
Good afternoon,
We have a search widget enabled for several layers in a web app in Portal. In the respective map, we filtered out a certain subtype of one of these layers. When you click on a symbol in the map, that subtype is correctly not showing up in the pop-up window. However, if you search the name of an element that belongs to this subtype, the app will still take you to it and show the pop-up window. Does the search widget not honor the definition query from the map and show all results? Is there way to edit the search widget to not include these subtypes?
Thank you!
AdamBakiera
Spoke with Technical Support. There is a known bug and currently there is no timeline for a fix.
BUG-000109960: Unable to search based on descriptions when the Sear..
AdamBakiera
