ArcGIS Pro 2.5: How to delete multiple subtypes?
744
7
04-20-2020 03:04 AM
JamalNUMAN
Legendary Contributor
This should be easy but couldn’t figure out how to delete multiple subtypes
Jamal Numan
DanPatterson_Retired
From the help topics
Subtypes view—Geodatabases | Documentation
Multiple subtypes can be deleted at once by selecting more than one row using the Ctrl or Shift key.
JamalNUMAN
Thanks Dan.
I’m not able to select multiple rows with ctrl or shift.
Jamal Numan
I don't see anything selected... If your image shows a selection, then something is wrong with the selection method (click on the number)
To check, select one row  and see if the row gets highlighted, then select ctrl OR shift (not both) and see if others get selected.  If the row doesn't select, then something is up
KoryKramer
Esri Community Moderator
Hmm, yeah, I think that's the problem.  It doesn't look like it is possible to select multiple rows in the Manage Subtypes dialog.  I'll ping that team...
notify Help as well, it is explicit there is there is no bug posted
JamalNUMAN
Hi Kory,
Is it documented as a bug?
Jamal Numan
KoryKramer
Hi Jamal,
I am not able to find this bug documented anywhere, which means that it has not been reported to technical support.  I'm in contact with the development team so that they can look into it.  If you need a bug number to track, please contact Technical Support to log a bug.
Thank you.
