What laptop do you use?
669
04-19-2020 08:19 AM
NonieCastro
My #laptop won't process #3D in #ArcGISPro lessons. What laptop do you use? How often do you use 3D? Would it be a big deal if I couldn't? 95% of the #tutorials work just fine for me.
Here's an example of a lesson I can't complete:
Map Venice in 2D and 3D | Learn ArcGIS
Thanks!
DanPatterson_Retired
Did you check you ability to run Pro on this link?
ArcGIS Pro 2.5 system requirements—ArcGIS Pro | Documentation
NonieCastro
I did - results attached:
 Dell XPS MinimumDell XPS Recommended
skip 3d work, you will suffer.  Look for something that exceeds the Recommended settings.
It is a trade off between money and desired capabilities.  A desktop will always return more for your money, but you then lose portability.  I use a fully loaded Surface Book II since it is both a laptop and a tablet, however, it cost 40% more than my more powerful desktop with all the toys.
Good luck
