AnsweredAssumed Answered
tkinter in notebooks for ArcGIS Online
Question asked by r3weber on Apr 13, 2020
Latest reply on Apr 29, 2020 by j.cullen-esristaff
Keep getting this error when trying to use tkinter in arcgis notebooks hosted in ArcGIS Online.
TclError: no display name and no $DISPLAY environment variable
From what I have seen it this is an environment variable that needs to be set in the docker image.  Using %env DISPLAY= does change variable but doesn't seem to clear up the issue.  I will then get this error:
TclError: couldn't connect to display ":0.0"
Since I do not have the control to alter these docker images used for Notebooks in ArcGIS Online I am wondering if someone from ESRI can look into this so tkinter works in notebooks for AGOL.
My program runs fine when I run it from a jupyter notebook on my local machine.
The specified item was not found.
Outcomes
