Multiple Variate Combinations
262
04-08-2020 01:19 AM
JamieHollis
I have been using the expression "$feature.asset + ', ' + $feature.cleaned" and this has worked fine to give me multiple choices of "yes,yes,no or no,yes,no' etc.
I am now trying it somewhere else and should for no reason not be working, however the returning combinations are not showing when the expression is executed properly 12 out of 63 different cobinations are the only ones that return. I have plotted the points on the map to show the relevant combinations but they don't seem to be recognised by the expression.
Is there another expression similar to this to give me the desired outcome or is this a problem others have come across? Like I said usually this works fine so I am at a loss as to why it's not working now.
