Hot spot analysis - how to set distance band if no peak distance is found
880
04-08-2020 09:15 AM
GiuliaGuerri
I have a question about Hot Spot Analysis (Getis-Ord Gi*). I use points data of land surface temperature (that has been retrieved from Landsat images) with a minimum one neighbor distance of 30m.  I have to choose the distance band or threshold distance to apply to Hot Spot Analysis. With Incremental Spatial Autocorrelation tool no peak distance is found, so how could I set the distance?
Thanks in advance for your help.
Tags (1)
DanPatterson_Retired
Modeling spatial relationships—ArcGIS Pro | Documentation
in this section Distance band or threshold distance
and from here
How Incremental Spatial Autocorrelation works—ArcGIS Pro | Documentation
there is the What if the graph never peaks? section.
which has a recommendation
