Polygon to raster
682
04-04-2020 11:17 PM
hanakohinonn
New Member
polygon to raster
Hello everyone!
I am trying to convert polygon to raster.(The polygon file is  topographic land data.)
However,the output looks stretched. First figure if polygon data. Second figure is the output. As you can see the third figure, the convert did not success.
 I am stuck and not sure what to do.
I am using arcgis10.6. Any suggestions are most welcome.Please help me.
Thank you.
DanPatterson_Retired
run a "check geometry" and then if necessary a "repair geometry" tool from arctoolbox
hanakohinonn
New Member
Dear Dan
Thank you so much! Your advice save my life!
Best
hanako
glad it worked out !
JoshuaBixby
MVP Esteemed Contributor
Hanako, if Dan's suggestion to repair geometry works, please mark his answer correct to close out the question.  If you did something else to get it working, please share.
