Arcade Expression Calculations NaN values
2136
5
04-03-2020 10:42 AM
JasonSimpson
New Contributor III
I am in the process of creating a field calculation through expression for a popup and keep getting a return of NaN for records that have a zero dollar value in both fields. My expression is as followed.
Round(($feature["Field1"]/$feature["Field2"])*100,2) + "%"
Is it possible to create return text for all fields that have NaN as the value? I have created return values for fields with null values before, but I am uncertain if fields with NaN is possible. Thanks.
KenBuja
MVP Esteemed Contributor
You could wrap this in an iif to check if the value is zero.
IIf($feature["Field2"] === 0, "Zero", Round(($feature["Field1"]/$feature["Field2"])*100,2) + "%")
JasonSimpson
New Contributor III
Worked perfectly. Thanks for the speedy response.
KenBuja
Glad to help! Don't forget to click the Mark Correct button
XanderBakker
Esri Esteemed Contributor
Hi Jason Simpson and Ken Buja ,
Question... does this work? I am getting this error message:
Parse Error:Syntax Error: Binary Operator not recognised ===
... when using 3 equal signs "===".
And do you have 0 values or is the field empty (null)? If so you may need to change the expression.
KenBuja
You're correct, Xander Bakker that should just be
$feature["Field2"] == 0
