Align Shapefile with world base map?
732
04-01-2020 12:59 PM
BishalKhanal
my shapefile  has Nepal_MUTM_Central_84_Everest_1830 as the coordinate system, it does not align with the basemap, what can be the possible ay to have it aligned with the world base map?
DanPatterson_Retired
what is the coordinate system of the world basemap?  And projection-on-the-fly should take care of any projection differences, suggesting that one doesn't have a defined coordinate system, or one is defined wrong
BishalKhanal
The base map is the light grey canvas that automatically loads in ArcMap, layer properties shows the projection is WGS_1984_Web_Mercator_Auxiliary_Sphere and the shape file is in Nepal_MUTM_Central_84_Everest_1830
BojanŠavrič
What geographic transformation is used to convert between WGS 1984 and Everest 1830? It might be that your misalignment is caused by incorrect transformation or the lack of it.
