Append to Feature Class
1500
5
03-25-2020 11:55 AM
jaykapalczynski
Tryng to append a selected set of features to an existing FC
So I grab a point, create a buffer in memory, select counties in that buffer, then I want to write those to a multipart feature in an existing FC...
The selectedCounties.gdb has Feature Classes "CountiesDissolved" and "Counties_appended" in it
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Target Dataset: Dataset Counties_appended does not exist or is not supported
Failed to execute (Append).
I also tried as such
arcpy.Append_management(results, "C:\Work\CountySelection\Data\SelectCounties.gdb\Counties_appended", "TEST","","")
Any thoughts?
I am also going to want to add values to the FC attributes on the append but thats the next step I guess
point = arcpy.Point(coordinateX, coordinateY)
ptGeometry = arcpy.PointGeometry(point)
# FEED THE BUFFER ANALYSIS THE POINT GEOMETRY THE DISTANCE PARAMETERS
arcpy.Buffer_analysis(ptGeometry, 'IN_MEMORY/BufferGeom', distanceMeters)
arcpy.env.workspace = "C:\Work\CountySelection\Data\SelectCounties.gdb"
arcpy.MakeFeatureLayer_management('CountiesDissolved', 'counties_lyr')
results = arcpy.SelectLayerByLocation_management('counties_lyr', 'INTERSECT', 'IN_MEMORY/BufferGeom')
arcpy.Append_management(results, "Counties_appended", "TEST","","")‍‍‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Think I got it working
Doing this....but wanting to create that FC in memory and not writing it to a FC to only have to delete it.
Testing now
arcpy.env.workspace = "C:\Data\SelectCounties.gdb"
arcpy.Delete_management('chihuahua_10000plus')
# Write the selected features to a new featureclass
arcpy.CopyFeatures_management("counties_lyr", "C:\Data\SelectCounties.gdb\chihuahua_10000plus")
arcpy.MakeFeatureLayer_management('chihuahua_10000plus', 'Counties_append')
arcpy.Append_management('Counties_append', 'C:\Data\SelectCounties.gdb\CountiesDissolved_append', 'TEST','','')
jaykapalczynski
 think I would have to merge or dissolve them first....the append them?
jaykapalczynski
Think I got it working..
Took the result and wrote that to the newly created FC
Then took that new FC and appended to the original FC
Testing
DanPatterson_Retired
Select Layer By Location—Data Management toolbox | Documentation
No 'result' assignment, hence it doesn't exist
arcpy.SelectLayerByLocation_management("parcel_lyr", "have_their_center_in",
                                       "c:/kamsack.gdb/city_limits")
jaykapalczynski
Testing now
jaykapalczynski
I ended up using an INSERT CURSOR
