Survey123: How to pre-calculate values for a field when the relevant question equals to false?
1731
03-26-2020 05:43 AM
Cyprus_Forest_Department
Hi all. I am currently facing an issue where I want a question to remain hidden from the user, and to be revealed upon an answer.
However, I want this field to be populated with a certain value when it is not appeared to the user.
It seams like the "default" option works for me if no relevant expression is set.
I have three fields:
  • Mixed_Hab (mixed habitat) that can be populated from a list of Yes,No
  • Perc_Primary (percentage of the primary habitat) that can be populated from a list 50,60,70,80,90
  • Perc_Secondary (percentage of the secondary habitat) that is calculated as 100-Perc_Primary.
I want to achieve the following automation for the user's input.
If Mixed_Hab = no, then:
  • Hide Perc_Primary in the form
  • Populate Perc_Primary with the value 100
  • Populate Perc_Secondary with the value 0
If Mixed_Hab = yes, then:
  • Reveal Perc_Primary in the form
  • Populate the Perc_Primary field with the value 50, and have the option to change the value based on the selection list of 50, 60, 70, 80, 90
  • Populate Perc_Secondary with the value 100-Perc_Primary
I have currently achieved the following:
  • Perc_Secondary remains blank
  • Populate Perc_Secondary with the value 50, and change it upon the input of the field Perc_Primary based on the calculation 100-Perc_Primary
I have attached the form for your convenience. Sorry for the unrecognized characters, its Greek...
Thanks in advance for the support.
JamesTedrick
Esri Esteemed Contributor
'Relevant' does not mean that the question is hidden; it means that the question is not being asked as part of the survey (and thus it's value will be null).  You can create the workflow of having a question that is initially non-relevant and store a value by creating a 3-question set:
1) The user-response question that has a relevant condition (q1)
2) A hidden or calculate question that stores the value when the user has not provided input (q2)
3) A calculate question using the coalesce(${q1}, ${q2}) function to store q1's value when present and otherwise use q2's. (qfinal)
q1 and q2 can have the bind::esri:fieldType value set to null as we don't need to store those values, only final's value.
JamesTedrick
Thank you very much, it worked!
