Attachment Viewer - no attributes
592
03-24-2020 12:51 AM
MaciejFlorczak
Hi!
I have a problem with Attachement Viewer. The app doesn't load attributes of my objects. It says literally "no available resources". The app works on a web map that is used in many other apps and everything works fine there.
Tags (1)
SarahMcDonald_Esri
Hi Maciej,
Would you be able to provide the link to the app? Are you using any custom attribute displays like arcade or pop-up media?
Thanks!
Sarah
MaciejFlorczak
Hi, this app is not public. But the layer (public transport stops) is available in some public apps. I find problems with this specific layer in dashboard (beta) - no attributes, in map viewer (beta) - the layer is invisible, in experience builder - no attributes. You can open this map in dashboard/map viewer/ experience builder -->  https://um-warszawa.maps.arcgis.com/home/item.html?id=eafe003e18044408adbcd860006ca7f0
As I said before, the layer works well in "old" apps.
