Edit Query Widget in Web App Builder
362
03-19-2020 02:50 PM
JessieShapiro
I'd like to make a small change to the query widget in my web app. I'm using the Web App Builder Developers Edition to create this web map and it contains one point layer and a polygon layer. When using the query widget on my point layer, the non-queried points do not drop off once the query is applied. This is a feature in the filter widget that the query widget does not have. How would I edit this in the javascript code so that non-queried for points do not show up? I'd like to use the query widget rather than the filter widget because I will be allowing the end-user to do additional spatial queries.
Thanks for your help
