Can I import a shapefile to Postgres database from ArcGIS Pro?
4909
13
03-18-2020 11:19 AM
IreneAlberty
I want to import a shapefile to my PostGIS Database (Postgres) using ArcGIS Pro, as QGIS does with Database Manager.
George_Thompson
Esri Frequent Contributor
It is a geodatabase or just a DB?
What is the license level of ArcGIS Pro being used (Basic, Standard, Advanced)?
You should be able to add a new feature class to a Postgres DB from ArcGIS Pro.
--- George T.
IreneAlberty
My Postgres DB has already the PostGIS extension, is it enough?
thanks!
BruceHarold
Yes
IreneAlberty
It's Postgres DB with a PostGIS Extension.
My license level of ArcGIS Pro is Basic.
I've tried to use the tool Feature Class to Geodatabase, with my Postgres DB connection but I got the error "000210 Cannot create output".
Which tool or process do you recommend?
Thanks!
BruceHarold
Please try Feature Class to Feature Class
IreneAlberty
I've tried Feature Class to Feature Class and got this error:
ERROR 000210: Cannot create output C:\Users\GIS_User2\Documents\ArcGIS\Projects\MyProject\psql-prcave-hub-dev.postgres.database.azure.com.sde\vieques
Failed to execute (FeatureClassToFeatureClass).
BruceHarold
I suspect the PostGIS spatial types are not enabled in your database, please see the PostGIS documentation referred to in our help:
PostGIS is a third-party, open source installation. To use the PostGIS geometry or geography type, install PostGIS on the PostgreSQL database cluster. Once installed, either use the PostGIS template database to create a database containing the PostGIS types, or configure an existing database to use the PostGIS types. See PostGIS documentation for information on the installation and configuration of PostGIS.
IreneAlberty
Thanks for your answer.
I've just checked the PostGIS installation and the geometry columns in my database: I have the installation and the spatial types (geometry).
Do you suspect anything else?
Thanks!
