Geocode service suggest problem when apostrophes in address
671
03-17-2020 09:42 AM
MaximeDemers
Occasional Contributor III
I encounter a problem when using the suggest method of a geocode service hosted on ArcGIS Server Enterprise v10.6.
If there is an apostrophe in the address name, the suggest method have difficulties to return suggestions.
For instance, in the location table, I have addresses such: 351 RUE DE L'ERABLIERE
When I use the suggest method with the text ERABLIERE, I dont have any result. When I use L'ERABLIERE, I have many results. If I use LERABLIERE, without the apostrophe, I have also many results.
I would like to be able to use ERABLIERE and got results. Is there something I can do?
RachelSears
Hi Maxime,
Have you installed the ArcGIS Server 10.6.1 General Geocoding Patch
This patch addresses several issues with custom locator services published to Server.
- Rachel
MaximeDemers
Thank you Rachel for your reply. I'll try installing the patch and see if the problem is solved.
MaximeDemers
Hi Rachel,
I did install the patch but the problem remains. Any other suggestions?
