Evalutate System generated Fields
315
03-17-2020 01:44 AM
MartinLueckel
Since ArcGis Server 10.7 it´s able to configure autogenerate fields for a line or polygone features. The fields contains infromation about the area, length and range of a feature and the values are autogenerated due to the geometry.
If you like acces these fields, called st_area or st_lenght, you get a correct value, if you have a connection to the ArcGIS Server established. In an offline environment, access a geodatabase, the attributes of this fields a gerated correctly, but inspite of the connected environment, the attributes of these fields are not filled.
Question is: How can we get values for this autogenerated fields in an offline environment ?
