Hello, I am developing a work order tracking system, and some job types are easily recorded by Quickcapture (Debris pickup), and other job types require multiple fields to be filled out (Concrete work). Instead of having the users go back and forth between the 2 apps, is there a way I could use a Url Scheme to open the Survey123 form from quickcapture?
Thank you,
Mike
Solved! Go to Solution.
We will be releasing an integration between QuickCapture and Survey123 in version 1.7 to be released in September 2020. The designer will allow the configuration of buttons that can launch Survey123 and prepopulate questions.
Hi Mike, we have this in our backlog already and are planning to implement it for a future release.
Mandy
