what is wrong with this
1239
7
03-10-2020 07:43 AM
PSGeo
hi guys,
I am using ArcMap 10.5.
I have a tool that adds the name of the location automatically based on the name of the folders (where are located the mxd and the gdb) and the date that has manual input.
The fact, I ran the script in stand-alone and it worked perfectly. However, with the python addin included it doesn't work...
I am sure it works after the "try:" but before it I don't know what am I doing wrong. Please can someone tell what is it.
cheers
Pedro
here is the code:
import arcpy
import pythonaddins
import os, sys, string
import arcpy.da
from arcpy import env # needed for env.workspace definition
import traceback # needed to log errors
import datetime
import uuid
class Island_1_upload(object):
    """Implementation for Island_1_addin.combobox (ComboBox)"""
    def __init__(self):
        self.items = []
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWW'
        self.width = 'WWWWWWWWWWWW'
    def onEditChange(self, text):
        global imageDate
        imageDate = text
    def onEnter(self):
        import arcpy
        import pythonaddins
        import arcpy.da
        import datetime
        import uuid
        if any(char.isalpha() for char in imageDate)==1:
            pythonaddins.MessageBox('Wrong characters in the date. Please try again!', 'Warning', 0)
        elif len(imageDate)<> 10:
        else:
            try:
                startTime = datetime.datetime.now()
                print startTime
                date = imageDate
                error_code=0
                # Checking the length of string values - if the input parameters defined wrongly, the process will not start
                if len(date) <> 10:
                    RaiseWarning("PROBLEM: Wrong date: <"+date+">. It has to be exactly ten characters long.")
                    error_code = error_code + 1
                try:
                    datetime.datetime.strptime(date,'%Y/%m/%d')
                except ValueError:
                    RaiseWarning("PROBLEM: Wrong date format: <"+date+">. It has to be year/month/day -> yyyy/mm/dd.")
                # mxd and environment; and gdb sources and targets‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
nested try-except blocks are iffy and your first one seems to be missing an except.  Did you truncate the rest of the code when copying?
PSGeo
hi,
the 'try' has the 'except'. Like i said the everything works on standalone mode after the first try... but I cannot make it work as a tool or button in the arcmap (addin).
that's why i asked what is wrong on that first part before the 'try'.
JoeBorgione
I don't see an except partner for line 41 try....  Also, line 21 shows an invalid syntax when I paste your def into spyder.
## replace with
elif len(imageDate)!= 10:
PSGeo
believe me it is there in the end of the rest of the script.
I fixed the != .
the result of all this after creating the add-in is in the picture
JoeBorgione
Okay.  I believe you!  Try eliminating some of the code and see if your addin loads.  For example, take out the second Try except block, etc.
PSGeo
 Just cleaned... but still the same things is happening...
there is no area to write date and enter
import arcpy
import arcpy.da
import datetime
import pythonaddins
import uuid
def count_records(fc):
    """ Create table from FC in order to speed up the count process, which is slow because the complexity of the GDB, return: the number of records in the FC in string format """
    fc_view = "in_memory\\"+fc + "_view"
    if arcpy.Exists(fc_view):
        arcpy.Delete_management(fc_view)
    arcpy.MakeTableView_management(fc,fc_view)
    count = str(arcpy.GetCount_management(fc_view).getOutput(0))
    arcpy.Delete_management("in_memory")
    return count
def RaiseWarning(msg):
    """ Print and log warning message """
    arcpy.AddWarning(msg)
def SysExit(msg):
    """ Print and log error message before interrupt script """
    arcpy.AddError(msg)
    script_end = datetime.datetime.now()
    sys.exit()
class upload_1(object):
    """Implementation for 20200324_upload_1_addin.combobox (ComboBox)"""
    def __init__(self):
        self.items = []
        self.enabled = True
        global imageDate
        imageDate = text
    def onEnter(self):
        else:
            try:
                print startTime
                 # Script arguments - input parameters
            ##    arcpy.GetParameterAsText(0)
                date = imageDate
                mxdInicio = arcpy.mapping.MapDocument('current')
                mxdPath = mxdInicio.filePath
                issue_code = os.path.basename(mxdInicio)
                issue_code = issue_code[0:19]
                issue_code = issue_code.replace("_"," ")
                mxdPathList = mxdPath.split(os.sep)
                IssueGDB =  "\\".join(mxdPathList[:-1])
JoeBorgione
That's the only thing I would be doing; starting at the bottom and either eliminating or commenting out blocks of code and see where it finally loads into your addin; then focus your efforts on the the last block eliminated.  Trouble shooting is an iterative process.
