ArcGIS Pro 2.5: Publishing maps with ArcGIS Online option ends up with “basemap” error and “feature template set” warning,
980
03-06-2020 11:23 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to resolve the with “basemap” error and “feature template set” warning that come up when publishing with ArcGIS Online option
Jamal Numan
JonahLay
Hi Jamal,
You are encountering the error because you do not have a basemap. A basemap is required when sharing a web map. Inserting a basemap will resolve the error. Please see the following doc: 00216: Map does not contain a basemap—ArcGIS Pro | Documentation.
For the warning, see this: 24041: Layer does not have a feature template set—ArcGIS Pro | Documentation
For future reference, you can open the associated help topic to the errors and warnings by right clicking on the message. A context menu will appear which provides a link to a help topic that describes the problem and lists available solutions.
Analyzer message context menu
Analyze your GIS resource—ArcGIS Pro | Documentation
Cheers,
Jonah
JonahLay
Hi Jamal,
Cheers,
Jonah
JamalNUMAN
Hi Jonah,
Thank you for the help
Not user why these should be requirements for publishing! That doesn’t make sense for me. I assume that publishing needs to be straightforward with minimum prerequisites.
Jamal Numan
JamalNUMAN
I got that using the “publish web layer” tool has less requirements and does the job perfectly
Jamal Numan
