Is this the best surface I can get from SRTM?
302
03-02-2020 06:48 AM
EduardoMachicado
Hi, I have been trying to model a surface using SRTM 1ArcSecond data.
The Hillshade I can generate though is very "grainy"? Is this the quality I should expect from an SRTM DEM? Some of this "bumps" are clearly buildings and/or vegetation. What would be the best to clear this and produce an smoother result? I tried using Focal Statistics, but the only thing I manage is to make the dem less sharp.
Can you point me out in the right direction what would be the process workflow for something like this?
DanPatterson_Retired
https://www.usgs.gov/centers/eros/science/usgs-eros-archive-digital-elevation-shuttle-radar-topograp...
30 m resolution is pretty coarse by todays standards.  It is useful for large areas and/or areas where there is no continuous coverage from other sources.
