Webmap retains scales from previous basemap
385
03-03-2020 03:58 AM
MarkCooper5
Occasional Contributor II
Hi
When we create a webmap it uses our default, which is a cahced map on our server. If we want to change it to a different basemap (in the most recent case ESRI UKs OS Greyscale Tile), the webmap seems to retain the scales from the original map rather than those that the new basemap is designed for. Does anyone know a way round this? Ideally we could open a new map without a basemap at all like you can in ArcMap or Pro.
Mark
Egge-Jan_Pollé
MVP Regular Contributor
Hi Mark Cooper,
Cool, I didn't know these Free Services | Esri UK yet.
When you use the OS Open Greyscale as a basemap, it will only allow you to zoom in to a certain level:
https://www.arcgis.com/home/webmap/viewer.html?webmap=93320e50f3f3419795946b1243aadb1e
One option would be to build a web app, using the Web AppBuilder, as this will allow you to add additional levels of display (LODs) - see for example this thread.
HTH,
Egge-Jan
