Unable to assign work in workforce, based on pre-defined zones
467
03-02-2020 03:48 AM
SimonLaw
Hi there
I am following the examples in this workbook workforce-scripts/3 - Assigning Work.ipynb at master · Esri/workforce-scripts · GitHub
Because i want to assign work to our workforce based on the predetermined zones from an existing feature layer on the map.
I have completed my code section like so:
for assignment in assignments:
    contains = squadZones_df["SHAPE"].geom.contains(Geometry(assignment.geometry))
    containers = squadZones_df[contains]
    if not containers.empty:
        squadZone = containers['OBJECTID'].iloc[0]
        if squadZone == 2:
            assignment.worker = squad_WSFF
            assignment.status = "assigned"
            assignment.assigned_date = datetime.utcnow()
        elif squadZone == 5:
            assignment.worker = squad_LL
        elif squadZone == 8:
            assignment.worker = squad_WG
        elif squadZone == 11:
            assignment.worker = squad_RR
        elif squadZone == 16:
            assignment.worker = squad_HLG
        elif squadZone == 18:
            assignment.worker = squad_JE
assignments = project.assignments.batch_update(assignments)
However, I keep getting this error:
File "C:/Users/.../PycharmProjects/APITesting/assign_work.py", line 45, in <module>
File "C:\Users\...\AppData\Local\Continuum\anaconda3\lib\site-packages\pandas\core\frame.py", line 2970, in __getitem__
if com.is_bool_indexer(key):
File "C:\Users\...\AppData\Local\Continuum\anaconda3\lib\site-packages\pandas\core\common.py", line 130, in is_bool_indexer
raise ValueError(na_msg)
ValueError: cannot index with vector containing NA / NaN values
Can anyone help with this at all? My feature layer table looks like this:
Thanks!
SimonLaw
UPDATE
  It looks like this part here:
    print(contains)
Is actually returning "None" in the field values, I added the print check to confirm my suspicions.
0 None
1 None
2 None
3 None
4 None
5 None
However, the assignments are being found ok and the df is being created fine as well with all data contained within.
Does this help anyone with my query?
by Anonymous User
Not applicable
Do you have a geometry engine in your python environment (e.g. arcpy or shapely)? If you don't the API will return None rather than True/False. You can install it via
conda install -c conda-forge shapely
