AnsweredAssumed Answered
Error Code 500 when trying to Publish Survey123 Connect Survey
Question asked by rex.robichaux_VADEQ on Feb 28, 2020
Latest reply on Mar 31, 2020 by sjeng-esristaff
Hello GeoNet... I'm pretty stumped on this one. I have a relatively simple S123 survey that is pulling a non-hosted feature service from a server that (IS) federated / serves as a hosting server. However in our dev environment, we often have to test with both hosted and un-hosted feature services. The eventual production deployment of such a survey would have to point to an enterprise geodatabase and thus, non-hosted feature services are our ticket.
My survey points to a point feature class and a non-spatial table in an enterprise geodatabase that have a  1-to-Many relationship class created. The relationship class uses the StationID field (the field is present in both the FC and table) as the primary / foreign key fields. GlobalIDs have been added and both the table and FC have archiving enabled. I was able to get the survey looking / feeling like I wanted but when I go to publish the survey, I get this following:
...which is really weird because when I click the submission url hyperlink I am able to go to:
 with no problem at all.
I'm not sure why Survey123 Connect thinks this API sharing endpoint is not accessible but I'm pretty hung up on it. Any help or ideas anyone might have would be welcome. The Map Image Layer and underlying feature layer are shared with the required groups in Portal, and showing under my content in Portal as well. Thanks for any help you can provide!
Outcomes
