I'm new to CityEngine and in 30-days trial. I'm using CityEngine 2019.1 and following the CityEngine Tutorial in Download Tutorial and Examples. But whenever Generate models, this error shows up.
"The rule file '...cga' contains errors. Check the 'Problem' view."
And this error happens to every rules, even the rule in ESRI.lib
I've uninstall and try to install CityEngine so many times but it not help.
I'm running CItyEngine on windows 10.
Solved! Go to Solution.
I got the problem when I could run CityEngine without problem on another computer.
In this computer, my document folder is D:/!Documents/ and my default workspace is on that folder. So CityEngine got all those problem because my folder has symbol "!" . When I change name of document folder to D:/Documents/, CityEngine could run succesfully.
I'm not sure.
LotInner --> Lot
