How to change the color of the marker/point that has been dropped on the map?
1354
02-25-2020 12:59 AM
SiyabongaKubeka
Good day
Is it possible to change the colour of the point that I have dropped on the map? Please see my code below:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>DEA GIS APPLICATION</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/widgets/Sketch",
        "esri/Map",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView"
      ], function(Sketch, Map, GraphicsLayer, MapView) {
        const layer = new GraphicsLayer();
        const map = new Map({
          basemap: "streets",
          layers: [layer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 5,
          center: [90, 45]
        const sketch = new Sketch({
          layer: layer,
          view: view,
          availableCreateTools: ["point"]
        view.ui.add(sketch, "top-right");
        sketch.on('create', function(evt){
                                           console.log("X = ", evt.graphic.geometry.x);
                                           console.log("Y = ", evt.graphic.geometry.y);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Regards
Siyabonga Kubeka
RobertScheitlin__GISP
try.
      sketch.viewModel.watch('state', function (state) {
        if (state === 'ready') {
          sketch.viewModel.pointSymbol = {
            type: "simple-marker",
            style: "circle",
            color: [255, 0, 0],
            outline: {
              color: [50, 50, 50],
              width: 1
try.
            style: "circle",
            color: [255, 0, 0],
            outline: {
              width: 1
SiyabongaKubeka
Thank you very much Robert, it works.
