Download option is disabled
1398
13
02-24-2020 07:50 AM
KrishV
Occasional Contributor III
Hi All,
I'm using Enterprise sites 10.7.1
When I click on any of the attribute, I'm getting below error instead of Chart. Also my download option is disabled. I'm using Feature Service and Shared to everyone if I have to change anything.
Even, if there are one unique value, instead of showing some graph, it shows empty chart. Is it expected behaviour.?
Please suggest.
Krish
by Anonymous User
Not applicable
Is this a secured service?
KrishV
Hi Graham Hudgins
No, I have shared with everyone.
Krish
by Anonymous User
Not applicable
Might want to move this into support to get these details. Downloading only functions for hosted feature services with extract enabled. Can you check the server version you're using?
Nicole_Ueberschär
You mean the Export option when I publish the layer? I am having the same problem...
Nicole_Ueberschär
Ok, I managed to have the download option available but the statistics are still failing to load:
(same error for all attributes)
by Anonymous User
Not applicable
sorry yes - I believe it's the "Export" setting on the hosted service. When enabled, the server will list `extract` as a capability.
KrishV
Hi Graham Hudgins‌,
Published a feature service without extract capability (10.6.1) to ArcGIS Server and used it in ArcGIS Hub then we were able to download the service.
Same process we followed now (tested with extract capability also). We have the download options disabled in both ArcGIS Hub and Sites.
Also, when i used 10.6.1 feature service in the sites, download status shows as shown below:
Nicole Ueberschär‌: Were you able to fix?
Krish
Nicole_Ueberschär
Hi Krish,
Only the download is working now. Did you try a different browser yet?
by Anonymous User
Not applicable
Thanks all for the extra details. To recap:
  • Downloads in Enterprise do not work like they do in Hub--in Enterprise we only can rely on the portal's download capabilities which are more restrictive than the download system in Online. There is an enhancement request to add this download system to Enterprise which customer support can add your name to if you'd like. It's something that is under consideration for a future release of Enterprise. The UI bug that Krish pointed out is being resolved as well in a later version of Enterprise Sites (10.8.1)
  • For the charts, we'll investigate a 10.6.1 service against 10.7.1 Enterprise Sites and see if we can reproduce.
