Record Set interactive table input
245
02-24-2020 10:34 AM
DavidPike
MVP Frequent Contributor
I'm attempting to set up a geoprocessing task to be set up on portal 10.7.1 and desktop 10.5.1.
My desktop script tool takes user input by them filling out rows in a table as an input parameter. This is done using the recordset data type (much in the same way as a feature set allows interactive drawing) and a template gdb table located in the datastore.
Regardless of any other functions of the tool, when published the input options for the geoprocessing widget are 'table in map' or 'json'. Table in map is useless as it just takes the data from a table in the layers, with no interactive editing allowed, and the json is just a string which my users would have no idea what to do with.
Thanks for your time
