Conditionally set field to be readonly in Survey123
4104
7
02-20-2020 06:47 PM
YuyingLi
I would like to set the fields read only based on the coniditions (the preivous choice)...Can I do that? Here is what I put the the read only column for the field:
if (${purpose}='inplementation', 'yes', '')
The purpose field is the dropdown - based on the selection, the other field (B) will either read only or editable.
But with the fomular, the field B becames read only no matter what the drop-down selction is.
Any suggestions?
Yuying
by Anonymous User
Not applicable
Is there a typo in your formula?
Easier to do it without the if i.e. in readonly:
${purpose} = 'implementation' or ${purpose} = ''
Cheers,
Chris
by Anonymous User
Not applicable
Cheers,
Chris
YuyingLi
Yes – thanks! Works great!!
Yuying Li, GISP
D 858.712.8381 M 858.380.8024
hdrinc.com/follow-us<http://hdrinc.com/follow-us>
by Anonymous User
Not applicable
Glad to hear we could help Yuying.
Can you please mark the answer as correct.
Thanks, Chris
JamieKelly1
Will this also work in the webform?  I tried and doesn't seem to work, maybe I am doing something wrong.
Edit:  Forgot to mention that it was working fine in the IOS app before I tried it out in the webform.
wilcow
did you get an answer to this? I'm unable (so far) to set a Multiple Choice question to Read only
JackFanZhang
As of Mar 2023, readonly still doesn't support formular on the web from... What a frustration. I hope the product manager understands their customers need an efficient form builder to build a form that behaves the same across the platforms (mobile and web).
LeilaJackson1
Occasional Contributor III
@JackFanZhang Agreed that this is really needed.
