ETRS 1989 UTM Zone 32N 8Stellen
1072
02-21-2020 06:24 AM
StefanieGerhard
where can i download the prj-file?
i relate to an article in arcAktuell from 2010, it's written there that you can download the file from the ESRI-page but i can't find it... thanx
MelitaKennedy
Esri Notable Contributor
I don't know where the link would have been, but here's the contents of the file:
PROJCS["ETRS_1989_UTM_Zone_32N_8stellen",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",32500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["Esri",102329]]
StefanieGerhard
Thank you but what should i do with this "content"? I will search for the projection on the internet now... hopefully...
MelitaKennedy
I'm sorry for the delay in answering. You can copy the string to a text file (use Notepad). Make sure that it's one line. Save the file with a .prj extension. Now you can import it in ArcGIS Pro through the coordinate systems dialog/picker.
