ArcGIS Pro 2.5.0 /Config Switch Changed?
337
02-21-2020 07:52 AM
MKa
Occasional Contributor III
In the new version of ArcGIS Pro 2.5.0, the /Config Switch on the command line or shortcut target has changed.  I upgraded from 2.3, and my command line used to be this
"C:\Program Files\ArcGIS\Pro\bin\ArcGISPro.exe" /config:MYPROGRAM.proConfig.X
now it has to be this
The problem with this, is that I configured a shortcut that was added to the users desktop to use the former, now I must run an install program on all of my user machine to remove and update the shortcut on all my users desktops?  Is this a known issue and is there any type of workaround I can do?
Tags (1)
UmaHarano
I see this issue too. I have contacted the development team to see what has changed at 2.4.
Uma
UmaHarano
This has been fixed in version 2.6. Pro 2.6 will be released in summer.
Uma
