Explore tool loses selected setting
322
02-20-2020 01:12 PM
JoeBorgione
ArcGIS Pro 2.5 currently (and earlier....)
Is there a trick to keeping the explore tool settings?  If I do any sort of movement around the map pane, turn layers on/off etc, I always have to reset the explore tool to get results.  See below:
Kory Kramer
KoryKramer
Esri Community Moderator
Hi Joe.
I did a quick check and don't see that behavior in Pro 2.5.  Is it the same for you in all maps?  If you copy/paste that map into the same project, does it act the same?  Different project?
Sorry I can't be of more help, but I don't see the same thing you're seeing.  Will require some troubleshooting.
Cheers
JoeBorgione
I think it's something I must be doing; an office mate says he's never noticed it.....
