"No centerline found at M Value = ....." - Anyone seen this before or know what causes it?
546
02-19-2020 06:52 AM
Labels (2)
ErinLesh1
New Contributor III
NathanEasley
Hi Erin,
Can you verify the route, centerline, and centerline sequence records are in alignment for the route you're trying to edit?
Nathan
Esri Roads and Highways team
RyanKoschatzky
Occasional Contributor III
I know that the route and centerline records where in alignment. I didn't check the centerline sequence record at the time. In another version, the centerline sequence record appears good. There was a centerline split applied to the active section.
