Hello!
Some time ago, I inserted a transparent image in the layout to use as a background for the caption. After inserting it in the layout I adjusted it to the desired size (rectangular).
I recently moved the image to another folder and renamed it. Of course I forgot the detail of the path in the layouts!
To repair the broken path I used the code (below, available at https://desktop.arcgis.com). However, when I open the project, the image is in another size (square).
Is there any way to avoid this and preserve the size?
Thanks!
The following script will find an image by name and set its data source to a new location.
import arcpymxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")for elm in arcpy.mapping.ListLayoutElements(mxd, "PICTURE_ELEMENT"): if elm.name == "Photo": elm.sourceImage = r"C:\Project\Data\NewPhoto.bmp"mxd.save()del mxd
