Survey123 notification of image (in data)
210
02-19-2020 10:12 AM
codysifford
I am looking for a easier solution for...if someone inserts an image (takes a photo or inserts) in a image question, that within the data table, a "image_attached" fills a cell in the data form.
Basically the people reviewing the exported excel table want to know if there is an image attached to a survey (within the table itself).
I could add a check box or yes/no if image is attached question for the surveyor but was hoping to have this hidden and viewable in the exportable table.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Cody,
You could have a calculate question that checks to see if the image question is filled out:
if(string-length(${imgquestion}) > 0, 'yes', 'no')
Note that there is one case where this won't work - if using the web form and taking an image with the device's camera.
