Open Coordinate Conversion widget with multiple conversions by default 4.X
4740
6
02-16-2020 05:16 PM
ClintonLunn
I'm trying to find a way to open multiple conversions when I first open a coordinate conversion widget. I did not see a setting in the documentation that would allow for this.
Is there a way to do this so that the user does not need to open multiple conversions at every page load?
Thank you!
Clinton
LeoLiu1
Add this line after widget created.
ccWidget._expanded = true;
LeoLiu1
Hi Clinton,
Which version are you using? The latest one is configurable:
ClintonLunn
Thanks for the reply, it looks like you're referring Web AppBuilder. I'm using the ArcGIS JavaScript API.
LeoLiu1
Here is a simple sample I modified from online sandbox, basically it's just
coordinateCoversionWidget.conversions.add(new Conversion({
    format:SUPPORTED FORMAT
<!DOCTYPE html>
<html>
 <head>
 <meta charset="utf-8" />
 <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
 <title>CoordinateConversion widget - 4.14</title>
 <link rel="stylesheet" href="https://js.arcgis.com/4.14/esri/themes/light/main.css" />
 <style>
   html,
   body,
   #viewDiv {
     padding: 0;
     margin: 0;
     height: 100%;
     width: 100%;
     overflow: hidden;
 </style>
 <script src="https://js.arcgis.com/4.14/"></script>
 <script>
 require([
   "esri/views/MapView",
   "esri/widgets/CoordinateConversion",
   "esri/widgets/CoordinateConversion/support/Conversion",
   "esri/Map"
 ], function(MapView, CoordinateConversion, Conversion, Map) {
   var map = new Map({
     basemap: "topo"
  var view = new MapView({
    container: "viewDiv",
    map: map,
    center: [-117.049, 34.485],
    zoom: 12
  var ccWidget = new CoordinateConversion({
    view: view,
    multipleConversions: true
  var formatsName = ["dd", "ddm", "dms", "mgrs", "usng", "utm", "xy"];
  for(var i=0;i<ccWidget.formats.items.length;i++){
   var f = ccWidget.formats.items[i];
   if(formatsName.indexOf(f.name) > -1){
     ccWidget.conversions.add(new Conversion({
       format: f
 view.ui.add(ccWidget, "bottom-left");
 </script>
 </head>
<body class="calcite">
 <div id="viewDiv"></div>
</body>
</html>
ClintonLunn
This is pretty close to what I'm looking for, but I've got my coordinate conversion widget in an expand widget. I'm trying to open all of the coordinate conversions once I initially press the expand button. I hope that makes sense.
So, once I press the expand button, I will see this (meaning that I would not have to hit the blue highlighted button to see all of the conversions):
I combined your sample and an expand functionality to help illustrate 90% of what I'm looking for.
<!DOCTYPE html>
<html>
<head>
 <title>Expand widget - 4.14</title>
<style>
 html,
 body,
 #viewDiv {
 padding: 0;
 margin: 0;
 height: 100%;
 width: 100%;
 </style>
<script>
 require([
 "esri/Map",
 "esri/widgets/Expand",
 "esri/widgets/BasemapGallery",
 "esri/widgets/CoordinateConversion/support/Format",
 ], function (Map, MapView, Expand, BasemapGallery, CoordinateConversion, Format, Conversion) {
 var map = new Map({
 basemap: "satellite"
 map: map,
 zoom: 3
 //Coordinates widget
 view: view,
 container: document.createElement("div"),
 for (var i = 0; i < ccWidget.formats.items.length; i++) {
 if (formatsName.indexOf(f.name) > -1) {
 format: f
 // Create an Expand instance and set the content
 // property to the DOM node of the basemap gallery widget
 // Use an Esri icon font to represent the content inside
 // of the Expand widget
var ccExpand = new Expand({
 view: view,
 content: ccWidget
// Add the expand instance to the ui
view.ui.add(ccExpand, "top-right");
 </script>
</head>
<body>
</body>
</html>
LeoLiu1
ClintonLunn
Wow, that was simple. Thank you very much!
