AnsweredAssumed Answered
Can ArcGIS Pro convert Ground coordinates to UTM?
Question asked by MarkHotz on Feb 12, 2020
Latest reply on Feb 12, 2020 by Dan_Patterson
I have an AutoCAD drawing in ground coordinates and need to get this into a usable projection to use in ArcGIS Pro. Is ArcGIS Pro able to do this? I have the math that is typically used to do such a conversion (below), but I am not quite clear how to implement this in ArcGIS Pro:
To Transform Ground to UTM Coordinates
Example: Point100 (Ground) 13262.582 m N, 4380.119 m E
1. Shift back to the original scaled coordinate value:
13262.582 m + 6,000,000 m = 6013262.582 m N
4380.119 m + 410,000m = 414380.119 m E
2. Scale Point 100 from the Ground down to the Grid using the CSF:
6013262.582 m * 0.9996899303 = 6011398.051 m
414380.119 m * 0.9996899303 = 414251.632 m
Suggestions?
Thank you
Outcomes
