AnsweredAssumed Answered
Mosaic Dataset: Geographic (datum) transformation is "missing" even though I set the transformation
Question asked by Mary.G.McClellan@FloridaDEP.gov_FDEP on Feb 12, 2020
Latest reply on Feb 12, 2020 by Mary.G.McClellan@FloridaDEP.gov_FDEP
I am trying to add .sids to a mosaic dataset. The .sids are in the below projection, which I specify when adding them to the mosaic dataset:
PROJCS["NAD_1983_StatePlane_Florida_North_FIPS_0903_Feet",
    GEOGCS["GCS_North_American_1983",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS_1980",6378137,298.257222101]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["False_Easting",1968500],
    PARAMETER["False_Northing",0],
    PARAMETER["Central_Meridian",-84.5],
    PARAMETER["Standard_Parallel_1",29.58333333333333],
    PARAMETER["Standard_Parallel_2",30.75],
    PARAMETER["Latitude_Of_Origin",29],
    UNIT["Foot_US",0.30480060960121924],
    AUTHORITY["EPSG","102660"]]
The mosaic dataset is in this projection:
PROJCS["NAD83(HARN) / Florida GDL Albers",
    GEOGCS["NAD83(HARN)",
        DATUM["NAD83_High_Accuracy_Reference_Network",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[0,0,0,0,0,0,0],
            AUTHORITY["EPSG","6152"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4152"]],
    PROJECTION["Albers_Conic_Equal_Area"],
    PARAMETER["standard_parallel_1",24],
    PARAMETER["standard_parallel_2",31.5],
    PARAMETER["latitude_of_center",24],
    PARAMETER["longitude_of_center",-84],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["X",EAST],
    AXIS["Y",NORTH],
    AUTHORITY["EPSG","3087"]]
I'm using the geographic transformation NAD_1983_HARN_To_NAD_1983_2011, but I'm still getting the error 70116:
"Geographic (datum) transformation between the raster dataset and the mosaic dataset coordinate systems is missing."
Do I need to create a raster dataset and then add that to the mosaic dataset? I was under the impression that mosiac datasets would be able to handle rasters in different projections, but maybe that's only if the rasters are already in a raster dataset.
Any suggestions are welcome!
Outcomes
