ArcGIS GeoEvent Add-on- Strictly for Stream Services Only?
566
02-12-2020 09:21 AM
Amanda__Huber
MVP Regular Contributor
Hey ArcGIS Monitor‌ Team,
We just had a quick question- is the GeoEvent Add-on strictly for stream services only or can it also be leveraged for other input/ service types?
Thanks!
by Anonymous User
Not applicable
The "ArcGIS GeoEvent Add-on" is designed only for ArcGIS Server GeoEvent stream services. If you have the  ArcGIS Server GeoEvent Extension (10.3 or higher version) already running with a streaming data feed, you can use the ArcGIS Monitor's ArcGIS GeoEvent extension to monitor the number of events at a sample interval. The ArcGIS Monitor extension will connect to the defined GeoEvent server and retrieve statistics about the
server and its related traffic.
by Anonymous User
Not applicable
SpatialAmolOne92
New Contributor III
Hey @Anonymous User - Does this means that we cannot monitor ArcGIS GeoEvent using the extension unless we have stream services?
Looking forward to your insight.
Best,
Amol
