Calculating age with two fields in ArcGIS Pro
3368
02-10-2020 12:43 PM
KathyAdelman
How would you calculate age in ArcGIS Pro based on BornDate and DeathDate fields?  I am working on creating a feature class to map cemetery graves using the Collector app.  The two fields are both a date type.  I am trying to do this in ArcGIS Pro, which I am new at, and it looks like the formula to deduct the BornDate from DeathDate and divide by 365 is not working.
Any suggestions?
DavidPike
MVP Notable Contributor
Hi Kathy. Date fields are python datetime objects which can be handy.
Field 1 - Field 2     produces a TimeDelta object.
TimeDelta.total_seconds()  will produce the number of seconds of the timedelta object.
I believe the timedelta will take into account leap years so the result may be off several days from what you may expect.
Total_seconds = (TimeField1 - TimeField2).total_seconds()
SecInYear = (60*60*24*365.25)
Years = Total_seconds/SecInYear
This is very basic and prone to error. Hopefully someone can give a better answer
UriGilad_EsriAu
Hi Kathy,
Insert a new 'Age' field  (numerical).
Calculate 'Age' field using Arcade, and insert the following:
var startDate = Date($feature.startDateField);
var endDate = Date($feature.endDateField);
var age = DateDiff(endDate, startDate, 'years');
return age;
for details see the DateDiff function in:
Date Functions | ArcGIS for Developers
Hope this helps,
Uri
