I am trying to use the Ripleys K function in ArcGIS Desktop and the output graph result is not showing up. Is there a trick to get the output graphs to show up? I searched through all of my output folders and tried the analysis multiple times. An output table shows up, but not a graph. Thanks for any suggestions!
In ArcGIS Pro?
Multi-Distance Spatial Cluster Analysis (Ripley's K Function)—ArcGIS Pro | Documentation
Sounds like, it is optionally "nothing". Perhaps if you want to graph something, then you will have to create one from the tabular results.
Display_Results_Graphically (Optional) | This parameter has no effect; it remains to support backward compatibility.
I have the same question, the graph was created automatically in other versions (it did in ArcMap)? ArcGIS Pro 2.9 does NOT have such optional parameter (see image). Any ideas?
I agree it's a shame that the chart isn't generated automatically. Fortunately it's quite easy to create the chart from the output table.
Right-click the output table and choose to create a line chart.
I hope this helps!
Best wishes,
Lauren Griffin, Esri
