Severe Server Log Message 'Failed to return the service configuration'
2441
02-06-2020 10:03 AM
LaurenCardona
In ArcGIS Server Manager we are receiving some severe log messages that say "Failed to return the service configuration 'XXX'. Server machine 'XXX' returned an error. 'Item does not exist or is inaccessible.'
Can anyone help explain or trace why we would recieve this message and what we could do to fix it?
Thank you!
ShaneMiles
Ben Turrell‌ have you ever encountered this issue?
BenTurrell
Occasional Contributor III
Shane Miles‌, Lauren Rogers‌,
Have you checked the permissions on the Arcgis portal folder? Sounds like it may not have the correct permissions set.
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
EliasRex
New Contributor III
Was this ever resolved? I am encountering the same issue. I checked the ArcGIS portal folder for the correct permissions.
