Print Widget 300 DPI
1002
7
02-04-2020 04:29 AM
SrinivasaRao1
New Contributor III
We have been trying to resolve the issue on Custom Print Widget which we have developed for some of the templates but we are encountering issue for one template 22 X 34 size for 300 DPI where tool thrown error saying that "Timeout exceeded". Could any one help us in understanding this issue and solution to fix the error.
Tags (1)
ShaneMiles
Hi Udaya Rao‌,
Could it be what you have the esriConfig.defaults.io.timeout set to? The default is I believe is 60 seconds before returning an error. I hope this helps answer your question.
Shane
Noah-Sager
What print service are you using? Is it the Esri hosted utility print service on ArcGIS Online, or is this a print service you published to your own instance of Server?
SrinivasaRao1
New Contributor III
Published to our own instance of server
Noah-Sager
Is this using Web AppBuilder or Experience Builder, or a custom JS API app? I wonder if there is some issue with the size of the print request being too large for the server to handle, so it times out. Couple things to try: 1) reduce the DPI and see if the request passes, 2) try re-publishing the custom print service (did you use ArcMap or ArcGIS Pro for this?).
SrinivasaRao1
New Contributor III
Thanks for comments.
Using Web AppBuilder
Yes size may be large 22X34 only for this size we have seen issue with more than 300 DPI and less than 300 DPI is working fine
Publishing was done through ArcGIS Map GP service
Tried to republish the service many times but it was same issue
is there any other alternative solution to handle.
Noah-Sager
I would try republishing the print service with ArcGIS Pro, or reduce the DPI. Reducing the DPI by 50 to 100 shouldn't reduce the quality too much, but will definitely help with the size of the request.
SrinivasaRao1
New Contributor III
Its a client request, as I told it is working in less than 300 DPI and client requires on 300 DPI only. Please let us know if there is any solution on this.
