Calculate distance from one set of points to another set of points
437
02-02-2020 12:46 PM
TimothyEdmonds
My software is ArcGIS Desktop 10.4.1. Network Analyst.
I wish to calculate distance from one set of points to another set of points on a road network. Lets call the first set of points Stations and the other set of points Destinations. I want to calculate the distance from each station to each destination.
I have run through the ArcGIS Network Analyst Tutorial data, but I am still not sure how to do this. I would have expected that this would be a very common type of analysis. If anybody knows of a step by step tutorial for this, could you please supply a web link.
Many thanks, Tim
DavidPike
MVP Frequent Contributor
Do you have a Network Dataset? Searching for 'Route Analysis' should yield enough info.
TimothyEdmonds
Thanks David, I'll check out route analysis. I have two groups of points (A & B), and want a distance from every point in group 1 to every point in group 2, and then distance recorded in a distance fields on each record in Group A (Distance to Point B1, Distance to Point B2, Distance to Point B3 ... ).
DavidPike
Ah ok, I think you run an OD cost matrix, that will do it for every point to every other point, but just get rid of the unwanted records in the table afterwards.
TimothyEdmonds
I found the function I wanted. New Closest Facility did exactly what I wanted. Problem solved.
