Enterprise roles required for adding layers from Portal
280
01-30-2020 04:00 PM
BrianKimball2
I have a user who is trying to add layers from our ArcGIS Enterprise Portal(10.5.1) into Arcgis for AutoCAD370 and keeps getting an internal error.  I have made him MapPublisher.  As administrator I have no issue.  Any tips?
Randy_Garcia
Brian,
ArcGIS for AutoCAD 370 only takes from it the capabilities of the service, it cares only that the service is editable by a certain user. As a test navigate to the rest endpoint of the service. Something like this
https://myserver.domain.com/arcgis/rest/services/myFeatureService
See if that user can hit that same page but for the service you are trying to add, if they can, they should also be able to use it an ArcGIS for AutoCAD.
Is your enterprise setup federated?
